fyrstormer
Banned
Thread title changed to improve clarity. :duh2:
I installed an MC-E in my Arc6 a few months ago, after testing an MC-E in a McR20 reflector and found it produced a nice beam, but the Arc6 reflector is just a bit shorter and that's apparently just enough to open a bit of a donut-hole in the center of the beam. The darn thing is so bright it almost doesn't matter, but it was still a little unsatisfying to have to point the light a little off-center to get the brightest illumination on the target.
The best solution, I suppose, would be to install a different reflector, but the Arc6's reflector is a custom size and I don't have the wherewithal to design my own reflector and have it built. But I do had a couple sheets of flash-diffuser film laying around, so I figured I'd slap a piece on the lense and see what the resulting beam looked like. What I got was this:
Not a beam artifact to be seen, as you'd expect. I'm quite happy with the results. It loses a bit of throw as a result, also as you'd expect, but the Arc6 is intended to be a Wall Of Light flashlight anyway, so that's fine. It's still just as bright as my Mac EDC SST-50, so the loss in throw is only an academic point anyway (it reaches the tops of the trees across the street from my house), and now the beam is smoother than whipped butter.
Definitely something worth trying if you have a Wall Of Light with a hole punched in it.
