Re: Ideal Charging Current
This Duracell Go Mobile charger I'm stuck with for a week is obviously not ideal, as I say, in that it charges in pairs, but I can't even figure out what the charge rate is. On the back it says: "Output AA - 2x (2.8v -- 2.25A)". Does that mean the charge rate is 2.25A (which would be over the maximum 1C for Eneloops), or half of that: 1.125A per cell? And if it it *is* slightly over 1C (1.125C), how damaging is that?
There's no single right answer for what the best charging current is, so this is why you see so much conflicting advice.
I happen to think that 1000 mA or 1 A is "best" for AA cells like eneloops, but it doesn't mean 1 A is "right". Depending on the charger, 500 mA or 750 mA or 1500 mA could be fine too. It all depends, and possibly it only matters how impatient you are...
It appears that the Duracell Go Mobile is catering to the impatient crowd, by trying to charge in 1 hour. This is marketing at work, overriding the wisdom of engineers perhaps? I personally think a 2.25 A charge rate is pushing it too far and I would not like to use that charger. On the other hand, occasional use of that charger with eneloops probably won't harm them very much. Eneloops are quite robust and tolerant of abuse. Silverfox once tried to kill some eneloops by charging them repeatedly on a 15 minute charger (that's called battery torture), and the enleloops survived it surprisingly well.
What you must do with that charger is charge and use the batteries in matched pairs. Don't mix two batteries in the same channel if they have not been equally discharged.
