I currently use a P60 host (just a cheap Ultrafire WF-501B) mounted under-barrel on my .22Lr rabbiting gun.
This has a Cree R2 (XR-E) emitter which has quite a small hotspot, so throws quite well. The beam divergence is a good match for the scope field of view so works well without wasting lots of light where it is of no use.
What I am looking for is a replacement P60 module which will give me more light on the target, not just more light, but not as throwy as an aspheric set-up.
The new XML modules sound quite good, but several people have said they are similar to the P7 without the beam imperfections, however this means they will be more floody than I would need.
Despite this, will they give me more light on the target?
Is there a better choice to give me a similar size hotspot as the R2, but with more light?
