I've decided to test my LD20's reliability at both low and high temperatures.
Pictures coming soon... (deadline JUN,18)
Recently I got the Fenix LD20 R4, I did a quick test, and I put the LD20 in the freezer set about -25 Celsius for 15 min.
Next, I put it in the oven that I warmed up to 60 Celsius. After 10 minutes I checked, and it was fire hot! I'd say at least 150 C. After I took it out, the flashlight had some weird smell, the tailcap was puffed up and the whole light was smoking from the heat. I quickly put it in cold water, then took it apart. Turns out that I have cooked the NiMH batteries and they were stuck in the battery tube, it took me quite some effort to get it out. The lens were full of fog, otherwise the light survived with no noticeable dimming of the LED.
As for the batteries, the sticker on the outside was melted which caused the battery to get stuck and where the 2 batteries contact, some sort of black chemical came out.
Later, I am planning to put it in boiling water, and putting it in the freezer for longer, some drop tests as well was it will be my EDC for my summer trips/hikes which it would be used heavily. I'll report back somewhere around JULY 31.
