Hi I am really overwhelmed by this site, I had no idea that there was so much information and passion on torches. I have in the past be on holidays to places where we go out at night spotting wildlife, often high in trees but also small insect and bugs quite close up. I have only ever had a torch that is enough to stop me tripping over things but not for alluminating what is up in the trees. I need a torch that can be turned down low so as not to disturn the wildlife while walking along but able to spot them once you have found them. Last year in Brazil we met an English man with an Americal army torch which was amazing and could light up well enough for us to take photos of Kinkajoos etc in the trees. I am going to Madagascar this year and would love to have a torch that could do something similar. I have tried to answer the questions below. I hope that someone will help me I don't expect I will be a regular to this site, but it certainly is amazing.
____I would like to purchase the light from a brick and mortar store. I am located in _New Zealand_____________.
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $300.
3) Format:
____I want a flashlight.
___
4) Flashlight-specific format/size:
____Every day carry medium (4-7 inches). or a little bigger if need be.
5) Emitter/Light source:
____I don't know.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use? I have no idea
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to be able to spot wildlife in trees with enough light to maybe photograph them while not blinding them forever. I am not worried if the photo are not perfect but would like to know what the creature is when I look at the photo.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 5 yards/meters looking at insects and bugs at night close up
____5-20 yards/meters walking through jungle/forrest
____30-50 yards/meters
____150+ yards maybe
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
____I don't know.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Less than $300.
3) Format:
___
____I don't know.
6) Manufacturer:
____I don't know.
____I don't know.
____Holster
