foxtrot824
I just can't stop building these things! The build theory on this one was to use the shining beam 3 mode driver (2.8A on high, LEDs wired in parallel) with some LEDsupply XP-G R5 triples to make a cool white burner. I had begun this build some time ago and just had not finished some of the delicate details of the build. While it is simple in theory to make a large part of the difficulty is getting the negative contact to make proper ground. I had considered making these for sale at a larger scale but have found they are too labor intensive (or I'm not a good enough machinist) to produce in large quantities. On a side note, the little jig I used to hold the driver and snug I picked up from harbor freight helps tremendously to hold little projects like this one. I'd strongly recommend one to any modder.
Enjoy!
Enjoy!
