Lightfoot98
Found this in an old reflector assembly. Don't know what
kind of flashlight it was from. Looks like a regular reflector from
any standard flashlight. Metal with a screw in plastic sleeve
plug to hold bulb.
Bulb is a PR style base with straight sided globe with lens at tip.
Globe diameter is slightly smaller than the base diameter.
Globe length looks same length as base.
Marked "KSA-3 USA" stamped into base.
Found 3 adjustment washers between bulb and reflector.
Any Idea as to what this is????
plug to hold bulb.
