Hello to all CPF members, I'm new and hopefully I'm doing this right...
Looking to update my current work light and I'll like to hear your opinions/advices. Currently I have a Surefire G2 LED. I like the durability and I thought the output was good enough. Lastely I feel like I need more output. Water Resistant/Shock resist/and output is my first concerns. Modes are not necessary and just need something at a reasonable price.
Thank you.
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____keep it reasonable.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Holster carry.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a tail mounted switch (found on the majority of today's high end lights).
____A simple on-off with only one output level is fine for me.
14)Material/Finish/Coating
____Flexibly
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Holster
Thank you.
3) Format:
____Holster carry.
6) Manufacturer:
____Flexibly
____Holster
