tommydonovan
- Joined
- May 26, 2010
- Messages
- 21
Hello all,
I am modding a stream light sl-20. I have a dx reflector/heatsink and 5 XML t6's. I have an upgraded battery in the light. A 6v 3500MaH NiMH. The reflector can be seen here:
http://www.dealextreme.com/p/53mm-3...nd-accessories-for-5-cree-xr-e-emitters-18842
It fits into the light well. My question is what should I use for a driver. Ideally I would have one that would run the LEDs at full current (3A) if for only a short time and have a lower constant use mode (1A each- still about 2000 lumens I think) I've thought about direct driving them and figured that the five of them in parallel would sag the battery far enough to not blow them up(surely that battery back cannot deliver more than 15A?) this would probably damage the battery? Or start a fire? Lol. I don't want to change batteries because I like the fact that I can drop this whole light into the charging cradle.
I am fairly new to this so forgive my ignorance how should I drive them? Or with what? Thanks in advance.
