!!!PICTURE!!! P60 THROWER Drop in Cree XRE-R2 EZ900 Small Die High Surface Brightness
Status
Not open for further replies.
Skylumen
vinhnguyen Cree XRE-R2 EZ900 Available Now, EZ1000 also available!
Last Updated: 4.16.2012
I am able to get EZ900 XRE-R2 LED now. They are expensive though! $45 for EZ900 pill only. EZ1000 are $35 for pill and reflector. Both will be driven to 2.1A.
I have played with many EZ900 and EZ1000 and my conclusion is if you want a P60 reflector XRE thrower then the EZ1000 is a better choice. You can barely tell any difference in brightness but the hotspot is a quite larger and thus lit an object better than the EZ900. I only see the EZ900 advantage when using a aspherical lens.
Paypal email: [email protected]
EZ900 1.8A VS Thrunite TN11
nc_hooper
Re: vinhnguyen54 P60 THROWER Drop in Cree XRE-R2 EZ900 Small Die High Surface Brightn
Is it possible for you to make a Dereelight "pill"? I'm currently running a DBS Aspheric with an XRE-R2 EZ1000 running at 1.4 amps. Also, are your drop-ins potted?
Thanks,
Andy
bigchelis
Prunedale, CA
Thanks,
Andy
Andy,
A P60 Pill is a Dereelight Pilll. They are interchangeable. When you purchase Vinny drop-in, well just un-screw from reflector and screw into Dereelight. thats it.
bigC
badtziscool
:takeit:
2) $38 EZ900 XRE-R2, SMOOTH reflector, 1.8A Single Mode 3-13V Max
Is this just an interest thread or a sales thread? I'd like to send PP when there's definite production.
Thanks! :lovecpf:
nc_hooper
Andy,
bigC
Bigchelis,
Thanks for the information - did not know that. I'm currently running a NB XR-E R2 EZ1000 at 1.4 amps in my DBS Aspheric and it works quite well. Significantly brighter than my Deft EDC LR (they both project a die image of approximately the same size). Estimating about 60Kcd for the LR and about 90Kcd for the DBS. But a EZ900 running at 1.8 amps sounds worth trying. On a different trend I asked if Saabluster might offer the LR configuration (1.4 amp xp-c, 207Kcd) for the DBS but no definitive answer currently.
So is this an active sales thread? Can I place an order?
Thanks,
Andy
Skylumen
Of course it is possible. Mail me your pill and I will see what I can do! :)
Vinh Nguyen
9706 8th PL SW Unit 204
Seattle WA 98106
Thanks,
Andy
Skylumen
This is an active sale thread.
Bigchelis,
Thanks,
Andy
Skylumen
Go ahead and send your funds
:takeit:
Thanks! :lovecpf:
PoliceScannerMan
Gainesville,FL
:paypal:
2) $38 EZ900 XRE-R2, Choice of SMOOTH or OP reflector, 1.8A Single Mode 3-13V Max
Smooth reflector please!
Also sent extra for the U2 XML repair. :D
BTW: I forgot to put my return address on the package, nor did I write PSM inside the package. So when a box shows up with no return address and a blown DD XML U2, its mine. :eek:
Thanks Vin!!! :rock:
:thanks:
Skylumen
:paypal:
:thanks:
Thanks! :)
Skylumen
Pics? I am interested.
The drop in looks just like anything other P60 Drop in. The EZ1000 already threw farther than the Thrunite Scorpion V2 With Turbo head. I am sold my first EX900 already which threw even better than the EX1000.
tundratrader
Homer, Alaska
Pics are important regardless. Dropin pics plus your dropin VS other drop ins would be helpful to see.
RCantor
KC, MO
If you had a 4B or 4C tint I'd buy one.
dirtech
Pocatello
I will take
Smooth reflector please.
Also from your other thread.
I will take
5) $47 3.15A Regulated 2 or 3 mode 3-6V Max
Smooth reflector, 3 mode, 4000k tint.
I would like thermal injection for both, if possible, and some aluminum adhesive. I understand there may be a wait for parts and build times.
Paypal for $85 is sent (Unique Transaction ID # 6LT05502JS281933W)
Skylumen
Order recieved!
I will take
I will take
Skylumen
I just placed an order of 25 CREE XRE-R2 LED straight from Cutter. So much $$$$$ YIKES! They provide the best LED quality though! Reflectors/Pills, Drivers and other parts cost more $$$$...I am broke LOL
Status
