Great little torch Bribo.
You mentioned trying to machine titanium, in my experience in turning, drilling and milling titanium is that it's not really any harder to cut that 300 series stainless steel in most cases.
It can be drilled with reasonably high quality HSS drill bits so long as it's not allowed to overheat and swarf is cleared every few mm, a few drips of bottled cutting fluid helps.
The same with HSS mill bits, so long as their sharp and cuts are firm but not excessive (0.1mm pass) it will cut well, again use cutting fluid.
If you have indexable carbide tools turning titanium is no trouble at all, in fact it's good fun. Steel cutters will work but they must be very sharp, don't forget the fluid (carbide bits don't seem to need it really)
Parting is the hardest task but do-able, again easier with carbide tools.
Don't be afraid to give it a go.
