Avatar28
A couple of years back my brother purchased a Quark AA² Turbo to take with him on his deployment to Afghanistan. He ended up having to use Alkalines in it at some point and they leaked. 4Sevens isn't willing to cover it under the warranty (which is unfortunate but I understand). I was able to remove the batteries and clean out the light. The head is fine, none of the leaking appears to have made it up there.
Here is the part where I'm stumped. When I put fresh batteries in there and try to use the light, it won't turn on. If I replace the tail cap with something conductive, a coin, a piece of foil, or whatever the light works as it should. Simple enough you might say, the tail cap is bad. I thought so too and ordered a replacement. The replacement still doesn't work. I have found that if I just hold the tail cap on the end without screwing it in place at all then the light comes on (just like my earlier tests) but as soon as I screw it on, it stops working. It probably doesn't make a difference but both tail caps are the tactical style.
Any ideas?
Any ideas?
