My Trustfire Mini-01 arrived today
Its a small, single CR123 light made from stainless steel with a perfectly centered T6 XM-L emitter. It cost $16.49 with free postage.
It came with a key ring attached, but the small split ring at the tail seemed a bit small and light weight, so i replaced it with a heavy duty split ring and lanyard.
The light weighs about 2oz incl the CR123, and measures 65mm x 20mm.
Fit and finish are good. Better than i expected for the price, only when twisting the light to activate it, it feels a little rough. This might just be due to the stainless steel construction, or the threads needing a good clean, i'm not sure. The light has 3 modes - High, low and strobe. It would probably make more sense if it had high, med and low instead of the strobe mode though.
The 2 O'rings on the light are GITD.
The light was advertised as 800 lumens, although i have seen the same light listed as 300 and 1000 lumens elsewhere :thinking:
At a guess, from comparing to a couple of other lights, i'd say it is about 400-500 lumens, so it's a nice little pocket rocket
Cheers
Matt
Cheers
Matt
