Ok, help me pick a new EDC light with a deep carry clip. I currently use a Quark AA with an AW 14500 and a deep carry clip. Let me know what lights come to your mind for this.
- No PWM
- Max length of 4.5in
- Tube-like diameter, similar to the Quark AA. Slightly larger diameter would probably be ok.
- Must have deep carry option. I don't want an inch of flashlight sticking up out of my pocket.
- 3 or more brightness levels, ordered LMH
- 18650 would be preferred but not required
I am considering at this point the Zebralight SC80 or the Eagletac D25LC2 Mini. The SC80 seems like an improvement in size compared to my Quark AA, as it is a decent amount shorter (though slightly thicker). It wouldn't be an upgrade in output, but with a 2500mAh eneloop XX or an AW 17500 I would expect better runtimes than the Quark AA 14500 with similar output. The D25LC2 will have better runtimes and output than the Quark AA at the expense of size. It is a decent amount longer, but same thickness. The obvious downside to this is that is is twisty and that it has no moonlight option.
Neither of these two are completely deep carry it appears. They would both stick out of the pocket some, though much better than the huge majority of lights.
Please weigh in on these two options and let me know of anything you think that would be better.
- No PWM
