I have purchased the components for this project. It's not quite what I was thinking originally, but the changes will better suit my application.
- (2) Radio Shack 3000mAh 7.2V NiMH R/C battery packs (23-431)
- (1) Female 4-pin Molex Connector (274-234)
- (2) Male 4-pin Molex connector (274-224)
- (1) Male/Female pair, 2-pin Molex connector (274-222)
- (2) 7.2V battery pack/RC car repair kit (23-444)
I used the Molex connectors and repair kits to make three adapters. I decided not to modify the battery packs in case I wanted to use a different set of packs, or use these for their originally-intended purpose. The first adapter has two Tamiya plugs (which mate with the battery packs) on one end, and a 4-pin female Molex on the other. The second has a 4-pin male Molex on one end, and a 2-pin female Molex on the other (the 14.4V output), wired in such a fashion so that the two packs are connected in series when this adapter is plugged into the first. The third adapter has a 4-pin male Molex connector on one end, and a battery-end type Tamiya plug on the other (this connects to the charger). This adapter is wired in a method that connects the two batteries in parallel for charging. Avoiding the useage of a project box keeps the entire thing small, in fact the two batteries are pocketable, side by side.
After charging both packs separately at a 1 amp rate, I checked the open-circuit voltage differential as 100mV. This is after one pack has been sitting idle for 3 hours, and the other fresh off the charger. As a test I then connected the packs in parallel through my ammeter...1.8mA. This would probably drop to 0mA once the "hot-off-the-charger" (in reality it was barely warm to the touch) pack settled down. (5 minutes after writing the above, the OC differential was down to 50mV.)
This is a picture of the whole shebang, meter showing OC pack voltage. Note the lamp fixture at the bottom left.
Here are the adapters. #3 (top) is connected to the charger's output (not shown), #1 is connected to the two battery packs(lower-left), and #2 is connected to #1 (lower-right), meter leads still probing the output connector.
My next step is to test the packs in series driving the lamp, and I'll watch the voltage output of both to see how far out of whack they might get.
(~15 minutes into the first test) One pack shows 7.31V, the other 7.29V. This is the very first discharge cycle, with no conditioning of the packs whatsoever. The lamp's base temperature is a sizzling 296 degrees celsius (565 degrees farenheit)...54 degrees C below the rated limit. /ubbthreads/images/graemlins/smile.gif Temperature rise (in still air, ambient room temperature) is ~100C (212F). The plastic "handle" remains cool to the touch however.
(~30 minutes into the first test) One pack is slightly warmer to the touch than the other. Its voltage is now 6.6V (1.1V/cell), my cutoff for this test. All cells in the pack are evenly warm, so I don't think I'm reverse-charging any here. The other pack is still 6.90V. It took slightly more charge than the first. Perhaps some cycling will even things out. The two packs recover to 7.16V and 7.44V. If I buss the two packs together at this stage, a 300mA current passes from one to the other, but this value steadily drops as the two packs equalize. I seriously doubt that any hazardous currents would be present after normal operation. Still, I will charge the packs separately one more time.
