speedywheelz123
- Joined
- Jul 23, 2011
- Messages
- 37
Hi, I am new to custom flashlights and want your opinion on a conceptual flashlight I want to make. So my plan is to make a flashlight out of 2 inch pvc and an mr16 bulb. I will use a 6 watt (supposed to be 500 lumen which i doubt). The mr16 bulb will hopefully (carefully) be glued into a coupler that joins with the pipe which does have an inside diameter of 2 inches (the same as mr16 bulbs). My main concern is that the pvc will either melt or cause the bulb to overheat. It is only 6 watts so idk.
