startravel
- Joined
- May 22, 2002
- Messages
- 35
Just receive 3W Star from ElektroLeumen. Thanks Wayne!
Very interesting, the 1W star uses aluminum-core PCB exclusively. The 3W star uses a standard PCB with a hole in the middle attached to aluminum star heatsink. The 3W emitter leads are attached to PCB. The emitter slug passes through PCB hole stopping flush to back of PCB. The PCB along with the emitter slug is then glued to aluminum star heatsink. This enables emitter slug to be directly glued to aluminum star heatsink.
I measured from bottom of star to top of black ring:
1W HD Star = 0.167"
3W HD Star = 0.162"
Difference = 0.005"
Luxeon data sheet shows:
1W aluminum-core PCB = 1.6mm or 0.063"
3W aluminum heatsink = 1.5mm or 0.059"
Difference = 0.004"
Is 1/1000" possible discrepancy responsible for improved heatsinking of 3W?
Is new process for 3W cheaper then old method?
Never seen a 5W star. Do they have a heatsink design similar to 3W or 1W?
I need someone to measure the black rings of bare emitters, 3W HD and 1W HD from bottom of slug to top of black ring to verify if there is indeed a discrepancy. The black rings could have been redesigned and have different dimensions.
Thanks,
Tim
1W HD Star = 0.167"
3W HD Star = 0.162"
Difference = 0.005"
Difference = 0.004"
Thanks,
Tim
