ftumch33,
If you want throw out of a 5W, you need to go with a bigger reflector that would have the ability to concentrate the beam of the light source in a 5W. I would suggest building a McLux PR head. It's still on the smallish side, but actually has some throw. Alot more than the L4 anyway. If you want throw out of the L4, mod it. Swap the lexeon for a 1W or 3W. If you plan to run it on an E1e body, you don't need to worry about messing with the circuit. If you want to run it on 2X123, you'll need to replace the circuit.
