Today while at work when I went to use the Fury on high, it kind of flashed up a little brighter then default at low. I'm using recent bought SureFire CR123A cells. I pulled the batteries and checked them and got 2.93 volts on each. Put in new cells but checked voltage first and got 3.26 volts each, now it comes on bright just fine.
What gets me is it specs for 1.5 hour run time before dropping to 50 lumens.
Thinking hard about it all, I know I have to have way less than an hour use on the pair of batteries. Way less the more I think about it. Could something be wrong with my Fury?
Any others think they are getting low run times using SF cells?
