SpecialtyLEDS
Hi,
I have a circuit made in PSpice, student version (pictured below). The circuit uses PSpice's D1N4148 diodes to represent ONE high power RED led which is rated at approximately 2.2 volts drop. I did this by adding three D1N4148 Diodes in series, which should be yielding 3 x 0.7v = 2.1v drop across the lines. But in this circuit, the model is showing that when I put the equivalency of 6 RED LEDS in parallel, the voltage drop is 3.4v which does not equal the projected 2.1v. Using a power source of 12vDC, you can see down below in _green_ the voltage drop across these diodes leaving 8.6v from the 12vDC power source, which means that the Vdrop across these diodes is 3.4v which does not equal 2.1v. Why is this the case?
What am I missing? Why would these models show that the diodes are dropping 1.13333 volts across each diode instead of 0.7volts?
* I NEED to use these resistors for the circuit - I realize that there are other ways of doing this. Can someone take a look at what I am working with here and give me any help?
