I know this has been beat to death, but I want to summarize the gems of information I've gleaned from the dozens of threads already related to this on CPF. There are some holes in some of these statements; I just don't know enough yet.
When a single AW RCR123A/14500/17670 cell is used with a Quark HV or LV head:
Thanks!
- The HV head will run regulated for about ~10 minutes (RCR123A) to ~20 minutes (17670) on Max, then go into direct drive and slowly fade away.
- The LV head will run regulated ____ times longer on Max, but end abruptly.
- The HV circuit is buck-only, which makes if more efficient. This means that the lower levels will run longer with the HV head (True?).
- The LV head will always trip the circuit protection of the cell (2.75V?); the HV head will simply cut off when the cell reaches below ____ V. It's genarally safer to have the HV head cut off, than have the LV head trip the protection circuit (True?).
- The HV head will lose turbo when the voltage drops below ____ V.
Thanks!
