I just ordered!
Description
Pre-order. Estimated shipping date: March 22, 2013
Main Features and Specifications
LED: Cree XM-L Cool White (Norminal CCT 6300K)
User Selectable Levels: 3 main level (High, Medium and Low). Each main level can be configured to one of its two sub-levels.
Light Output
High
H1 900Lm (tbd) or H2 500Lm (tbd) / 270Lm (tbd) / 4Hz Strobe
Medium
M1 90Lm (tbd) or M2 27Lm (tbd) / 9Lm (tbd)
Low
L1 3Lm (tbd) or
L2 0.6Lm (tbd) / 0.1Lm (tbd) / 0.02Lm (tbd)
Runtimes will be tested using ZebraLight ZL631 batteries. Light output are ANSI out the front (OTF) values. All levels are current regulated.
Operating Voltage Range: 2.7V - 4.2V
Battery: One 18650 size (up to 68mm long) 3.6/3.7V Li-ion rechargeable battery. Batteries are not included in the package.
Parasitic Drain: Negligible (much less than the self discharging of batteries)
Beam Type
80 degree spill
10 degree hot spot
Head Diameter: 30 mm
Body Diameter: 25mm
Length: 101.6 mm
Weight
tbd
Features
Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start)
Lanyard ring
Automatically stepping down from High to Medium, and from Medium to Low when battery capacity is low
Builtin over-discharging protection with 2.7V cutoff
Electronic soft-touch switch
Smart user interface provides fast and easy access to all brightness levels
Precision machined unibody casing from premium grade aluminum
Durable natural hard anodized finish (Type III Class I)
Ultra clear lens with anti-reflection coatings on both sides
Orange peel textured reflector
Battery reverse polarity protection
Waterproof to IPX7 (2 meters, 30 minutes)
Operations
This light has 3 main levels (High, Medium, and Low). Each main level can be configured to one of its two sub-levels. The second sub-level of each main level can be further configured to different brightness levels or strobes.
Basic Operation
Short click turns on the light to High or turns off the light.
Long click (press and hold for about 0.7 seconds) turns on the light to Low.
Advanced Operation and Configuration
Short click turns on the light to High. Short click again quickly to cycle from High to Medium, and Low.
Press and hold to cycle from Low to High, release to set. When press and hold, the light always cycle from Low to High regardless which level you are currently in.
Double click to toggle and select between the two sub-levels for that main level. Sub-level selections (except the strobe) for the 3 main levels are memorized after the light is turned off and through battery changes.
The second sub-level of each main levels can be configured after 6 double clicks. Double click (startng with the 7th) to cycle and select different brightness levels or strobes. Short click to turn off the light when finishing configurations. The selections for the second sub-level are memorized after the light is turned off and through battery changes.
This light uses the LEDs to indicate the estimated remaining battery capacity by flashing 1 to 4 times. To start the battery indicator, short-click 4 times without pause from OFF.
Description
Light Output
High
Medium
Low
L1 3Lm (tbd) or
Beam Type
80 degree spill
10 degree hot spot
Body Diameter: 25mm
Length: 101.6 mm
Weight
tbd
Features
Lanyard ring
Operations
Basic Operation
