florinache
A few days ago I made some tests with my HP11 to see if it could work on li-ion 18650 packs. That's where/when I got this idea from: http://www.candlepowerforums.com/vb/showthread.php?354012-*new*-Fenix-HP25
I temporary wired some homemade 18650 packs to the light and here are the obtained results:
I was quite satisfied with the running times, so I decided to permanently modify the lamp.
Materials:
The wire is cut, warranty lost
The coaxial cable:
Prepare to be soldered!
Cables soldered and some isolation tape added. On left of the image is the first layer of shrinking tube:
First tube shrinked:
Second layer. Doesn't look pretty but I tried to protect the soldered wires from bending and twisting. I'm sure it's quite waterproof:
A tiny bit of plastic hose for waterproofing the contacts:
I tested this on my other devices, it works well.
Some of my parallel battery packs. Simple, cheap and efficient, as long as you're not diving with them. Here you can see the use of the Svideo to 3RCA cable.
A few minutes later and the extension cable is ready. It looks flimsy but I used this type of cable with my bike lamp and it holds up well. Anyway, if it breaks I can still connect the batteries to my lamp directly :
The finished lamp:
A bit of sewing and the holder is done:
The smaller loop for the smaller pack, of course. I have to work some more here, I'm not quite satisfied with this elastic holder with one battery only. The light being lighter, I probably won't use the upper headstrap anymore.
A bit too colourful for my taste, but at least it's colour coded. Useless in the dark.
The original holder prepared to become a member of the new family...But not today.
It was fun, i'm not quite sure if it will hold well on the field, but that's OK, maybe I'll find out why I always carry the backup lamp.
I use the HP11 mainly in the forest and at higher altitudes on the mountain, and sometimes I really need the extension cable in winter and when wearing the climbing helmet.
That reminds me, let's talk about the weight. That's not a light for the ultralight hikers, but is a very good thrower and I prefer it to other lighter lamps.
So with 1s2p 18650 pack it's 60g (2.11oz) lighter and 55% more running time. Actually, if you consider the spare batteries (120g the AA's) but only one more 18650 for the same running time, the modded light is 150g (5.3oz) lighter.
Maybe I'll order some 3400mah Panasonic cells that will double the AA's running time.
Measured drawing current:
675h on low mode? Maybe it's the DMM I used...
Voltage:
4.28V Turbo --> at 3.55V drops to High --> at 3.1V drops to Medium
The light is dimming as the voltage drops, but that also happens with the AA rechargeables.
Battery pack type | turbo (277lm) | high (133lm) | medium (55lm) |
1s2p 2800mah 18650 Samsung | 6h:20' | 14h:25' | not tested |
1x 2800mah 18650 Samsung | 3h:05' | 6h:50' | not tested |
4x 2500mah AA Eneloop XX (it's own holder) | 3h:40' | 8h:30' | 26h:20' |
Materials:
- S-Video to 3RCA Adapter Cable From an old video card
- Coaxial audio cable (I don't know if it's the best idea, but it looked sturdier than a normal AV Cable)
- AV cable for the extension cable
- Shrinking tubes
- Electric tape
- 35mm elastic band
- 10mm transparent tube
The coaxial cable:
The finished lamp:
HP11 | weight in grams | weight in ounces |
before modding, without AA's | 190g | 6.7oz |
with 4AA Nimh | 310g | 10.93oz |
with 1s2p 18650 pack | 240g | 8.46oz |
with 1x 18650 | 210g | 7.4oz |
extension cable 90cm | 20g | 0.7oz |
HP11 (freshly charged batteries) | Lo | Med | High | Turbo |
4xAA 2500mah Eneloop XX | 20mA | 100mA | 260mA | 740mA |
1s2p 18650 2800mah Samsung | 8mA | 130mA | 340mA | 760mA |
Voltage:
