DellSuperman
Hi all,
I just tried reflowing of bare emitters on a triple MCPCB (from Illumination Supply) for the first time & I think I failed terribly.
So I have a few questions to ask before I try again:
1) Before reflowing the emitters, do I need to apply solder/flux on the positive & negative contact point on the MCPCB?
2) Will the emitters or triple MCPCB be damaged from high temp?
I placed the bare board on a hot plate before placing the emitters but I am not sure what the temperature is.
3) I kinda screwed up with one of the emitters, shorting the whole emitter totally & tried to run it.
I saw a spark at the wires & I knew something was wrong.
What will be the damage level here?
Will the MCPCB be damaged or just the emitter that is placed wrongly?
How about the other 2 emitters that is placed in the correct polarity?
Thank you so much...
- JonK
- JonK
