HydroDynamic
- Joined
- Nov 22, 2011
- Messages
- 26
Figured I would share the tech from the CPFM sale. This is tech only thread, no sales info.
L6 Lumamax factory body, bezel, clicky switch.
Emitter has been updated to Surefire Fury emitter and driver.
The only non Surefire parts are two stainless steel springs and machined delrin battery spacer.
Factory bezel and body have not been modified.
Beam is amazing for XML in that deep reflector.
For lumen rating and runtime, it is the same as a Fury. Expect higher efficiency from better reflector and glass.
The beam profile has a very bright hotspot and nice full spill. Long thrower with good spill to see what's on the ground in front of you.
The tint is very good for outdoor use. I prefer high CRI and I like this tint. The way the reflector distributes the XML colors works well.
The machined emitter and driver holder is a Fury bezel. The emitter was tapped and bolts down with heat paste. The emitter and driver holder can accept the current line of Fury and X series emitters and boards and future if they continue with current design. Only tool needed is small tap for the emitter.
Last photos are to show thermally that the light dissipates heat correctly. This reading was taken after about 20 min. runtime being held in 65 degree weather.
