Very right about that. High CRI is only measured based on light sources of the same CCT (Correlated Color Temperature) and is not an indication of full color accuracy but rather color accuracy based on the given color temperature of the light source. Frequently when shooting with a high CRI emitter, I prefer to adjust the white balance setting to compensate for the mostly warmer tint.From the beam shots it don't look like a mule. Is it from Oveready? I have a M61 219 that I sometimes use for photography but I read somewhere that cameras don't see light like we do and that HCRI is not as affective as one might think.
Yup incans are the best when it comes to color rendition. This is a custom drop in made by vinhnguyen54 on cpf you can contact him if you want one of these modules.This is a little off subject and I don't mean to side track this thread from LEDS but would incandescent lighting render color better than the HCRI nichia while taking pictures?
That mule is an ingenious idea. Where can I find a drop in like that?
Well, as has been discussed, while an incandescent light may have a CRI of 100, that doesn't necessarily mean it renders colors accurately, as seen by our eyes or a camera with it's white balance set to "daylight".Yup incans are the best when it comes to color rendition..
I think I'll have to setup a test. Shoot a scene lit by a Nichia 219, with the white balance set to daylight, and then shoot the same scene lit by an incandescent light, with the white balance set to "tungsten". It should be interesting.
