tobrien
I had two protected Orbtronic 18650 3100 mAh cells in an extended and 18mm bored 9P setup powering a Malkoff M61W L. I noticed two days ago when I set the light down on a table it came back on— regardless of the fact the switch was in the off position (a McClicky in an RPM tailcap). I thought it was real strange and clicked it to 'on' and then off which turned it off finally.
The next day, I successfully replicated the incident by knocking the light against my leg and it stayed on (again, despite the clicky not actually activating it).
I repeated this a few times yesterday and eventually the light just wouldn't power on at all. At first I figured the McClicky was loose in the tailcap, but felt the spring with my finger and it was nice and firm in its socket. Ultimately I tried two Redilast 3400 cells in there and the problems stopped.
Keeping that background info in mind, I got my Fluke 111 out and one of the cells read 0.00 volts DC. Is this the protection circuit kicking in? Why was the light turning on despite the McClicky being off?
Both cells were around 4.18 volts when they were put in the light so it wasn't a charge level issue I don't believe. Can anyone explain this strange behavior? The other Orbtronic cell read 4.15 volts when I checked them...
Again, I had a Malkoff M61W L, which I believe is at most around 350 mA current draw, so this was not a high power module to begin with.
Should I return this cell?
— Sent from my "not going to be released this century" iPad 62 'Quad' running iNOS (Apple's future neural interface OS) with the teleportation upgrade on Tapatalk 0.0.1.4 (beta) while Remote Desktop'd into Windows 98 SE.
