DIWdiver
After the failure of my full-custom attempt at an XM-L handheld with 1x 26650, I decided to try my hand at a mod. I looked around for a nice body, intending to replace the driver and LED. I settled on the MagicShine MJ-852, despite MagicShine's poor reputation for quality. I figured I could clean it up, replace the O-rings, and I was planning on replacing the driver anyway. Here's a picture of it as it arrived.
I did a pretty thorough evaluation of it here: http://www.candlepowerforums.com/vb/showthread.php?316449-Anyone-tried-this-light
I was hoping to use ahorton's 27mm aspheric lens, but there's just no way to fit it in the light. You'd have to bore out the head until the wall was dangerously thin. So I bought a couple aspheric Fresnel lenses from jspeybro. At 25mm dia and 2mm thick, it's a much better fit. The Fresnel lens is a compromise, not as tight a beam and not as bright, but it works quite well. I did a brief comparison of the lenses here:
http://www.candlepowerforums.com/vb/showthread.php?369326-ahorton-vs-jspeybro-lenses
It turns out I had to chuck the entire guts and rebuild the pill. The driver is two boards connected by three 1/8" diameter brass rods. The front board has the linear very-low-dropout regulator, and the back board has three hall sensors to drive the regulator in low-med-high (0.3A, 1A, 3A). I was quite impressed with the results when I put it all together and got it working at 8 PM the night I left for a week of diving. When I took beamshots today, I discovered the output is much lower than it should be. When I measured the tailcap current, it's only 2A. After the diving season ends in a few weeks, I'll tear it apart and figure out what's going on. Until then it will do quite nicely. It's my new favorite light. Here's a couple pics of the new pill.
and the lens and lens spacer
As you can see I machined a new aluminum pill. The LED is an XM-L2 T6 3C (5000K) on a 16 mm copper star from Illumination Supply. It's glued in with Artic Silver epoxy. The driver board is screwed to the back of the pill, and there's a thermal pad between. Max power dissipation of the driver is around 2.5W, so that should be sufficient. The wires were soldered to the LED before installation, and solder directly to the driver board, so they are only about 3/8" long, 24AWG solid copper.
I deliberately defocussed the beam slightly to remove the artifacts in the image of the die. Here's a beamshot. The light is 10 feet from the target, and you can see the inch and cm markings on the scale. At 20" it's about a 10 degree beam (some would call it 5 deg). My cheapo lux meter shows about 650 lux max.
Hope you guys like it! I like it enough I think I'll make a spare. And my dive buddy on my last dive wants one too. It was every bit as bright with a wider beam compared to his 10W HID canister unit!
