HKJ
[size=+3]Panasonic Lithium Industrial CR123A[/size]
Official specifications:
This is the industrial version of the Panasonic CR123 battery.
The rating says max. 1A, but I test up to 3A.
These batteries does not have a colorful retail package, only a sealed plastic bag for each cell.
Except at 3A the curves are basically the same as the retail version. When getting down to about 1 volt they do have slight more capacity.
[size=+3]Conclusion[/size]
The performance of these batteries is basically the same as the retail version.
[size=+3]Notes and links[/size]
The batteries was supplied by cpf user "Candle Lamp" for review.
How is the test done and how to read the charts
CR123A and rechargeable substitutes
Panasonic Lithium Power CR123
- Nomial Voltage: 3V
- Nomial Capacity: 1400mAh (Cutoff at 1.8 volt 20°C)
- Standard discharge current: 20mA
- Maximum discharge current: 1000mA at 20°C
- Mass: Approximately 17g
- Operating temperature: -20°C to 60°C
- Storage temperature: -20°C to 45°C
- Recommendeble storage: 5°C to 35°C, Humidity: Less than 70%RH
