HighlanderNorth
There wasnt enough room in the heading to type out my question pertaining to this potential project. Here's my dilemna. I have never modded anything by adding a modern star mounted LED to it. This is the typical inexpensive outdoor landscaping lamp, with the solar cell on the top and a basic 5mm LED inside. They come in packs of 6 or boxes of 24 or more for not much money. I know how the various LED's used for flashlights perform, but when it comes to finding an LED for a lamp application where the light will be dispersed 360 degrees downward, I dont know which LED would fit the bill. Also, I have never wired an LED mounted onto a star, so I dont know exactly how.
Next, about the circuitry...... Can I simply wire the new Cree LED(whichever I choose) using the same wiring and circuitry as is used for the stock 5mm LED setup? I'd imagine that the new LED will be brighter and more efficient than the old LED, but I would like to definitely increase the brightness over where it is now, which isnt much BTW. They arent very bright. I'd say a 200-400% lumen increase would be nice. Will I get that anywhere near that level of increased luminosity using the stock circuitry, considering that the new LED is more efficient and brighter?
As far as the stock solar cell is concerned, I would imagine its not going to be good enough for this project. I would like to try adding a larger, round solar cell that covers most of the top of the lamp, instead of just a small area in the center of the top lid. I assume I should be able to find a solar cell that generates more energy per cubic inch versus the stock cell, no?
Here's problem #2. I have done multiple google searches to figure out how to do a project like this, but I cant find squat. I am doing this more out of curiosity than anything else. If it works well, maybe I'll make more of them. I dont want to spend a fortune on each one. Lets say $5 - $8 for the LED with star, .50 cents for replacement wiring if needed. I dont know how much solar cells cost, but lets estimate $15 for a circular cell approx 4" in diameter. Lastly, the circuitry. I dont know about that. Will I be able to buy a small, basic circuit for this project that will provide the correct current, voltage, wattage, etc, and be able to maybe cut off the lamp after approx 7-9 hours of run time?
What do you think? Will it work, whats involved, can I re-use some of the existing parts? Or, do you know of a good site where I can read up on how to do projects like this, in laymans terms?
