Phaserburn
http://www.coleman.com/product/1000-lumen-cpx-6-lantern/2000013865?contextCategory=1080#.Uv5vqWAo6mc Ok, just received this bad boy direct from Coleman ($61 including tax and shipping), so thought I'd post some initial impressions. When I read that Coleman released a warm tinted led lantern that was intended to compete with fueled ones, I impulse bit. So, rated at 1000/330/60 lumens, this lantern also has a slow flash feature as well (at full power). The UI isn't great, as you have to cycle through the levels to turn it off. Sigh; c'est la vie, I guess. Build quality is perhaps a touch above their previous led lanterns. The hard plastic has some softer rubbery feeling plastic in contact areas. The light is triangular when viewed from the top, all the way to the bottom for a prism shape. The 5 leds are mounted in a triangular pedestal that has what appear to be aluminum cooling fins all around it; it looks beefy. Capping the pedestal is a yellow colored, flat topped triangular cap. You can easily see this is what's mitigating the cool led color beneath. The result, like the GE 8D lantern, is a nicely tinted neutral white. There is a triangular reflector directly above the pedestal, and the plastic sides of the light portion of the lantern are completely transparent; no frosting, etc. The word Coleman is frosted on the "glass" on one side, top to bottom. There's a short metal bail as well. It's daytime now, so I'll post more impressions of tint and brightness this evening. I can say this - on high, holding the lantern, you can't look at it; it's too dang bright. I expect this lantern to be brighter than all other led ones I own (a lot...). We shall see. I will compare it to the GE, the Energizer new 8AA folding, Rayovac Sportsman, and Coleman 200 lumen camper. I can probably dig us a couple of others as well, like some fluoros.
