I think your question mainly depends on the Flux Bin you got for both emitters. The SBT-90 is basically a dedomed SST-90 and the emitting surface is the same size. So if you get the same lumens with both emitters you will have about the same throw. Judging from the data sheets on luminus website there are better Bins for SST-90 these days, so if you already have a high-Bin SST-90 you couldn't get a SBT-90 at the monent with a better surface-brightness, which would in your case mean a decrease in throw.
rayman
