Hi everyone, having got a fair bit of info off here over the last little while, I thought I would give back a little.
Just thought I would write up a few thoughts on my new LLP7.2. Go easy all you Flash-a-holics, remember this is only my experience based on normal day to day use, I am not at all concerned with the tint of the light or blinding astronauts etc, etc.
Firstly the build quality seems excellent, especially the new tail switch which is a lot better than the previous generation. It does feel really solid in the hand and the slide focus is easy to operate one handed (without feeling wobbly or loose). It is easily pocketable, but certainly not an everyday carry size.
The light output is more than adequate for what I require, and I really enjoy the ability to switch from flood to spot. For example, I was changing a fuse in a fuse box last night and I had it on the low setting with flood focus; the previous afternoon I was under a house and I was able to check out the condition of some stumps on the other end of the house with the high setting and spot focus.
The battery life seems fine so far, especially for the intermittent use I use it for in both my home and work life, and AAAs are cheap and easy to get.
I really like the simple interface: First click for high, second click for low, push again for off. Push and hold for boost. Maybe a third click would be nice for strobe, but hey, first world problems..
I also like that if anything goes wrong with it, I can return it easily.
I have sewed up and old head-strap with a loop of elastic so I can use it on my head (it is not a light you can comfortably hold in your mouth), after searching high and low for a helmet mount without success, I have decided to design and print my own and will let you all know how that goes.
Cheers, and have a great day!
Tristan.
Tristan.
