jawnn
A man on amazon said he tested the Nitecore EC20 and got much more run time than is stated on the package. Is that really possible?
"I tested 2 different batteries to see how long they could run when left on the 960 lumen power setting of the EC 20 flashlite. I used the ORBTRONIC 3400 mah with the Panasonic cell and labeled NCR 18650B (?) and the ORBTRONIC 3100 mah labeled Industrial NCR 18650A. The 3400 battery ran 2 hours and 40 minutes until the low level LEDs flashed rapidly and the flashlite showed 3 volts.
The 3100 mah Orbtrionic battery went 2 hours and 50 minutes"
Will the nitecore chargers charge the Orbtronic to it's fullest load? it stoped at 4.2 volts the only test I did.
