Tobias Bossert
For a caving light project I need a battery for a single cell light with buck or linear driver. The lamp will drain up to 3A on turbo. Most batteries do not deliver enough voltage under such high current drain.
As far as known from HKJs battery comparator LG 18650 D1 @ 4,35V should be best suited for those lights, because voltage holds highest even when most of charge has been extracted.
But the measurements from HKJ were carried out early 2012. I made now another measurement with two samples of the actual version of LG 18650 D1 and found this battery has changed internally.
The model E1 was developed later than D1 and LG specifies its capacity 200mAh higher than D1. But E1 is not really better than D1, since it shows larger voltage sag under load.
The recent version of D1 seams to have an increased capacity of 100mAh with respect to the earlier version. The capacity is now 100mAh below E1 only.
But the internal resistance has increased too, resulting in lower voltage at high drain currents: The voltages under load are now only slightly above those from E1 but much lower than those from earlier D1.
No good information for owners of single cell lights with buck or linear driver!
Keeppower offers now LG D1 and E1 cells with PCB . Akkuteile sells those batteries.
Be aware that the PCB of Keeppower does not allow to charge up to 4,35V completely. The overcharge protection jumps in at just below 4,35V. So you should use these batteries with 4.3V charger only. The protection adds about 13 to 16 mOhm.
