I have been reading about the break in mode of the c9000 and also the skyrc nc25000 that does the same thing.
They charge the battery for 16hours at .1C and rest for one hour, discharge it at .2C rest another hour and then charge again for .1C and its done.
What I dont understand is how charging at .1C for 16 hours doesn't hurt the battery because for example a 2000mAh rated battery, charging at 0.1C would put in 3200mAh.
So what happens after 2000mAh is put in the battery? Does it just converts the remaining 1200mAh into heat? What happens to that extra current?
With todays cells is this mode still necessary?
