Background
I have a strange question regarding NiMH cells, regarding the comparison of a standard LSD/ULSD cell to a high-drain NiMH with LSD inferior to the latter.
I have used eneloop and Tenergy NiMH AAs and AAAs for years. I have owned eneloops since generation 2. I am progressively replacing my older Tenergy and Eneloops (some with well over 500-750 cycles) with the newer eneloop 2100s and eneloop Pros. As I am in the US, this applies to Japanese made eneloops and not the Chinese made ones (which I hear are very inferior.) (My choice to move solely to eneloop is because, while the Tenergy AAs have been less than half the purchase price, my long-term cost of ownership is significantly less with the eneloops. This is not just because of the longer service life but actually because the eneloops hold a much higher capacity as the cells age.)
Historically, the eneloop XX (now Pro) has been marketed for use in high drain devices versus the standard eneloop marketed for cross-platform usage, ultra-low self-discharge, and a long life (which now exceeds 2,000 cycles, which is incredible.) With the considerably higher price of the XX/Pro, the faster rate of self discharge, and less than ¼ of the service life, the eneloop 2100 makes sense for usage in all but the most power hungry applications.
Current Gen AA Specs
The current generation eneloop 2100 is a minimum capacity of 1900 mAh. The current generation eneloop Pro (formally XX) is a minimum capacity of 2450 mAh. Like previous generations, both models consistently have higher capacity ratings that far exceed the advertisements, unlike the large bulk of NiMH cells on the market. This new generation makes incremental/evolutionary improvements over the last, but there is no doubt this new generation does a better job in temperature extremes, and the standard eneloop 2100 does a better job with higher drain devices than its predecessor.
My Comparison Issues
On most forums, the general response of a comparison of these batteries is that the eneloop XX gives about 25% more run time over the standard eneloop (and consequently, the price is hard to justify in most cases.) However, my experience has run completely contradictory to this.
Low Drain/Standard Applications
On one hand, with lower drain devices, I have found the standard eneloop to in some cases give 3-5 TIMES the run life of the XX. Presumably this is because these ultra low power applications benefit from the standard eneloops slower rate of self-discharge. That is easily explained and nothing out of the ordinary and it is a clear illustration of why the standard eneloop is the better choice for everyday applications and has an overall lower running cost.
High Drain/Power Hungry Applications
Here's where I get confused, with high drain applications. Based solely on capacity, numbers would suggest that the XX/Pro would provide about 25% longer run time. But my experience is completely different. When using the XX (and now Pro) with applications that tend to put a brutal drain on a battery, quite often the XX/Pro gives SIGNIFICANTLY longer run times over the standard eneloop that far exceeds the 20-30% increase based on standard capacity figures. For example, when I power a 16 foot high output LED strip, the 8+/- hour usable run time of the standard eneloop is better than alkaline, but the 12-14 hour usable run time of the eneloop Pros blow both away. With some other high drain devices, I see similar outcomes in which the run time increase is closer to 50% or greater. However, this is not always consistently across the board as the gain is much greater with some high drain devices than others.
HELP
On paper, that makes no sense. A battery with a min capacity of 2450 mAh versus a battery with a min capacity of 1900 mAh should not be all that different. But in the worst drain applications they sometimes are. Why?
Can someone explain this to me? I am currently debating whether to buy quite a few eneloop Pros for the purpose of running high-output LED light strips. I am playing with numbers and if what I am observing is NOT a fluke or error, my cost of ownership with the eneloop Pro would actually be LESS than the standard eneloop because the less frequent charging may offset the higher purchase price and lower service life. Additionally, the longer run time would benefit me since the power blocks that run these LEDs are in the far back corner of my safe and kind of a pain to replace. So am I making some sort of clerical error or does the eneloop Pro giving a benefit to high drain devices that is greater than the numbers would indicate?
I doubt this matters but I generally use a NiteCore D4 Digicharger/Intellicharger 2015 revision. In some cases I use an older Lacrosse. Thanks in advance.
HELP
