gunga
Hey all. Time to rotate the selection.
This time it's the sinner 18650 ti tri.
I modded the tail switch.
The sinners usually use a (large) brass contact disk in the tail with an Omten switch and a spring is needed on the driver. I found this to be too short on the 18650, so I used a lower profile Omten switch with a spring soldered to it (no brass disk). I used a 2mm thick brass disk in the head so flat top batteries work. I also adjusted the height of the switch buttons internally for better feel/action. I also bored out the 18650 to fit very fat batteries.
The LEDs are neutral XPG2 (5A2) with a 3 amp programmable driver from Dr Jones (lucidrv with ultra low moonlight mode programmed and 5 click mode lock).
Levels are.1 to 700 lumens?
The optic will be 10507, "throw", work a green glow sticker behind the optic!
I also used a blue Flouro polymer oring in the head but can swap to black/red/orange/green if you like.
The clip is a stainless with rounded head (for looks ) and upgraded torx bolts.
I've refinished the outside but it may show light carry marks. No dings.
Price is $210 shipped USA. Add $6 for worldwide. Any Insurance and tracking can be added at cost.
>> LIGHT HAS SOLD LOCALLY
