London666
- Joined
- Sep 25, 2015
- Messages
- 17
I was reading through the FAQ and stumbled across this:
"Series connections have a device's positive terminal connected to the next device's negative terminal. This is what you get when you line up some ordinary C-cell alkalines (for example) end-to-end, like in a Maglite or other flashlight. This arrangment adds up the voltages of the cells. Such a battery neither handles more current nor contains more mAh capacity than a single cell. "
I thought I understood the difference between series and parallel. Series increases voltage, parallel increases capacity without increasing voltage. But series doesn't increase capacity at all? 100 D cells in series would still have only 1000 mAh?
So, why do 3rd gen 3D maglites get about twice the cell life as 2Ds? Would an older 2D with Nite Ize drop in get the same battery life as a 6D with the same drop in? Or would the voltage limiter (which I assume those bulbs have) compensate and allow for better capacity as well?
As I said in my intro, I'm technologically illiterate. If someone could explain what I'm missing I'd appreciate it. My whole world has been turned upside-down!
