Hi,
I have been carrying my ARC-AAA LE for a decade and I think it is time to treat myself to an upgrade.
I have been out of the flashlight loop for a while and would appreciate any suggestions for a new light.
Here are things that are important / not important to me:
- It will almost always be with my keys so it needs to have a sturdy and reliable way to connect to a key ring.
- It will spend many hours/days in my pocket with keys and other stuff so the lens/led should be able to withstand scratching.
- Will be important that it can't accidentally turn on while in pocket.
- It will definitely spend some time clipped to a ball cap for use as a headlight so it has to have a reversible clip that will not come off or get lost. (That was my only complaint about my ARC-AAA - the clips would come off and get lost.)
- I would prefer it to be white without a tint – especially to not have a purplish or greenish tint.
- Small size is important.
- Well regulated would be great. (Maybe that isn't an issue any more?) I do not need any warning before it goes dead.
-- I will not be using a rechargeable battery.
-- Most of the time I would like to use alkalines; with an occasional lithium for cold camping trips.
-- It does not need to be able to tailstand.
-- Cost is not a big issue. If needed, I don't mind spending money to get a decent light since I will keep it for a long time.
As far as output goes, I am not too picky. My ARC does not have adjustable output levels. I unfortunately can't remember what it is rated at, but it works good for walking around in the dark or finding things and it also works OK for reading yet the battery lasts a good long time. That is all I really need; however, it would be a plus if it had a higher mode for brief non-standard situations.
Thanks for any help!
SAK
SAK
