Sold/Expired Brass 1x18650 Flashlight from CNQualityGoods - SOLD
DellSuperman
Singapore
Up for sale is this Brass 18650 light from CNQuality & modded to a triple XP-L HI.
Emitters are mounted on a Noticon Triple MCPCB & stacked on an extra 20mm copper MCPCB to give it extra height & heatsink. It has 2 x 3C & 1 x 1A emitter that I reflow myself.
The light engine is made of brass & has been drilled with a single hole in the middle for the triple MCPCB wires to go through it. The driver is the KD AMC7135 3.04A driver, set at LMH wo Memory.
I can set it at any preferred setting if you do not like this mode, just checkout KD driver & let me know what modes you prefer.
Disclosure:
Light has not been carried out before; just modded & tested at home.
There is a small scratch mark on the bezel that was already there when the light arrived.
Unprotected cells only because protected ones are too long & will not allow the light to be fully screwed in, it is light this even with the original setup (reflector)
Item comes without box but with a spare glass lens & some o-rings which all will be shipped together.
List Date: 1/17/2016
For more info, click here to view the original listing: Brass 1x18650 Flashlight from CNQualityGoods
SOLD
candlepowerforums
magellan
Honorary Aussie
USA
Re: Brass 1x18650 Flashlight from CNQualityGoods
Nice mod on a nice chunk of brass. I like my stock version but yours is even better GLWYS.
nbp
Wisconsin
Moving this out of Titanium lights to Custom and Modified. Best with your sale!
DellSuperman
Singapore
Sorry nbp, it was automatically posted by Panjo. Thanks anyway.. [emoji106]
nbp
Wisconsin
No worries my friend, all taken care of.
Free bump!
toastystuff
Did I misread or did you use 2 different led for this? If so why did you decide to go that route?
DellSuperman
Singapore
No, you did not read wrong.
I wanted to try out things out because I have seen other modders do this before.
The output tint is a good mix of neutral & cool white since the tint of the 2 different kinds are quite close to each other.
toastystuff
Ahh I see, Interesting. I wonder what a whitewall beam shot looks like. Got any?
DellSuperman
Singapore
Hey, i was away over the last few days & wasnt able to take a beam shot.
I will try to take one later & post it up..
DellSuperman
Singapore
Beamshot.
The CW emitter is at the bottom & the NW are at the top.
The warm light at the bottom is my house lamp, sorry about it.
VybhDUxWRpM-3_F_O5KAgY-ivF4aj3EN4KmmNi_ozuSxjIsWehXGgC7yypvZF5wHWdfS2Ibxd4sZfE8O_kT031jq6hfIQGRPol0XwXnS4HDhRXSkX0Jthy3yQYhrYuducdn-k-q3ICmSEE6JnnuXXAF74wpignQNtfdxqKQ577OLvLb2u2zh4PdYKGnoXCpwtf6aDpb9a0ApxSRUHRZZkgBrizxd6yxrHB6A_uuurpVPan4UlhhlikAFBiIyT1sI2BaqttjKXEyRmAye9GpSo_soop9bqXH13dMFe-jclDyDR3W6fka5apUJZ5qNMPvYji3FbiAxstfmsiYJbmhZQlRmhfh7yEuLQjzFA9LDbOBeXlxLPKCuwxiz2diH9AgYPSjdxAUcYxv1XBWUSrUFTI1fPcZU0kZD6mo3Hb02vGU1SQpzOC0SsrgnsCAUQtq50jvnsfheF8k1xqrUIPZbu4uWu4fGd6pdaSECPfA8JMuFnzFrWjuKOxx_nt0M112Bvl2Y_i0-y4N00pjZef6IGQj6OZLdXLTO64TSLEFNF3Gyd_JIXXiUTD4XjgtPWx1RwYta=w800-h450-no
magellan
Honorary Aussie
USA
I'll take it. Can pay in the morning as it's after 2 am here right now.
