So I just got a new E15 in the mail today as a backup to the one I already have. So of course I am itching to modify one on them. For me the color temperature of the new E15s are to cool, far cooler then the previous generation with the head the same size as the body. I would guess them likely cooler than 6000K. I have a nice 5000K Nichia 219C I want to drop in to one but can't for the life of me figure out how to get the head open. It is made up of a brass body with the circuit board crimped in the the base and an anodized aluminum head that is some how attached to the brass body. The aluminum head holds the optic in place and guards access to the LED side of the brass body.
So far I have tried uncrimping the circuit board but no luck you can only pull it out a few mm before the wires going to the LED become taught and I assume they are separate cavities with 2 holes for the wires to pass through. I tried heating the head with a heat gun and holding it with a silicone hotmit while using the crimp tabs as leverage to try and unscrew it with no luck. using a microscope to look down the crack between the brass and aluminum no threads or adhesive goop can be seen The aluminum just tapers until it contacts the brass which leads me to think it is a press fit.
Anyone have any experience or recommendations for me?
