Trying to find some help with this light. Just got the limited edition version 3.0 predator. Been using it for awhile now and started to notice that the light was not turning on in the max mode with the head tightened. I did replace the batteries and that kind a helped. What its doing is when I turn it on for a split second it will turn on the max mode on the head tightened. But as soon as I let off the tail cap switch its like it drops to 50% of the output. When I switch it on and off a few times it will occasionally stay on in the max brightness setting. If that doesn't work I can take the battery out and put it back in and that will sometimes solve the problem. I checked the batteries and they are new with a full charge ( 3 eagletac 18650 3500 MaH all batts do work the same in this light. Other lights I don't have this problem). I'v tried to contact Armytek but I keep getting there answering machine. I'v also tried to email them but don't get a response.
Any help would greatly be appreciated.
