medix
I know many of the recent posts have indicated that if you have a model 3 which takes 2xcr2016 cells, you can substitute a single cr2032 for dimmer, but longer lasting light. My question is if you do that, does this just reduce the current supplied to the led, or does the lower voltage cause the electronics to cycle the pulses to the led slower? Also if you supplied, say a red, with a set of 2xcr2016 cells would it destroy the led or the electronics since it is made to run off of a cr2032? The electronics for the higher voltage colors i.e blue, white work with half the voltage. Mabye all the colors use the same electronics that tollerate a wide range of voltage to keep costs down. Any info would be helpfull.
