BugoutBoys
Nitecore MH20GT
Manufacturer specs
LED: Cree XP-L HI V3
Max Lumen: 1000
Uses one 18650 rechargeable battery or two CR123A batteries.
Output/Runtime (1x18650): Hi 1000lumens / 1hr – Hi 410lumens / 3H - Med 230lumens / 6hr 45min – Lo 50lumens / 22hr – Lower 1lumen / 680hr
Output/Runtime (2xCR123A): Hi 1000lumens / 45min – Hi 410lumens / 2hr 30min - Med 230lumens / 4hr 30min – Lo 50lumens / 14hr 15min – Lower 1lumen / 340hr
Beam Intensity: 33,000cd
Beam Distance: 362m
Impact resistant to 1.5 meters
Waterproof in accordance with IPX-8 (two meters submersible)
Second generation 'Crystal Coating Technology' combined with 'Precision Digital Optics Technology' provide extreme reflector performance
High efficiency circuit board provides up to 680 hours runtime on low
Side switch interface provides one-handed operation and easy access to all functions
Side switch features an indicator light which displays remain ing battery power (patented)
Power indicator secondary function displays battery voltage (accurate to 0.1V)
Intelligent memory function stores preferred brightness setting
High-efficiency regulation circuit provides unwavering output
Toughened ultra-clear mineral glass with anti-reflective coating
Constructed from aero grade aluminium alloy with HAIII military grade hard-anodized finish
Stainless steel titanium-plated clip included
Tail stand capability
Dimensions: 4.13" (L) x 1.25" (Head Diameter) 1" (Body Diameter)
Weight: (3.08oz)(without battery)
Accessories: Quality holster, clip, tactical ring, lanyard, spare tail cap, spare O-ring
MSRP: ~$99
In the box
Appearance
The MH12GT has a black HAIII hard anodized finish over an aircraft grade aluminum body.
the knurling is of moderate aggressiveness and is in two places; the tailcap and center cylinder. partner these with the other design elements and the anti-roll is very good. The head has a lot of anti-roll design elements to it. The MH12GT can also easily tail stand to be used as a candle.
Overall grip is very good and very comfortable. The light feels very solid, yet lightweight and the size is absolutely perfect for an EDC light in my opinion.
The markings are grey and show up clearly on the body.
The finish is not Matte, but it isn't highly reflective either. Same as all other Nitecore lights that I have used!
The MH20GT has a 2 stage side button that is similar to a camera shutter. From off, a full press (click) will turn the light on to whatever mode it was last on in. From on, half presses will cycle through modes. A full click will turn the light off. From off, a full click and hold for 1 second will activate the light at full power. Same for half press and hold, but it will activate the light at lowest power. From on, a full click and hold will enter special modes. From here, half presses will cycle through the special modes and a full click will turn the light off. Only the normal modes have memory.
From off, a half press of the button will activate a "beacon" that flashes the blue LED under the button every 3 seconds.
When a fresh pair of batteries are put in the light, it will flash the battery voltage, accurate to .1v
Physical Tests
I submersed the MH20GT in water completely while pressing the side switch. I did not find any water to have entered the light at all.
The MH20GT has great thermal regulation and the larger head does a good job of dissipating the heat because it can be on full brightness for a while before feeling heat. It is a comfortable amount of heat as well, nothing unbearable at all.
Since the MH20GT is completely current controlled, there is no PWM on any of the modes.:thumbsup:
Drop test included all surfaces from carpet, to grass, to stone floor. No surfaces showed any damage other than concrete. The only thing that happened on the concrete drop was a few little "chips" or dings in the black. No performance was hindered, however; I would still always recommend doing everything in your power to prevent dropping any lights.
The MH20GT includes an electronic reverse polarity protection rather than a physical one.. If the battery is inserted backwards, the light will not work. Nitecore lights usually only work with button top batteries, however; I use flat tops (Panasonic) in mine and it works fine. I would still recommend getting button top when able.
When the battery is at 50%, the side button will flash every 2 seconds. When the battery is "low" it will flash rapidly.:wave:
The MH20GT also features a thermal regulation system instead of a timed step-down. The system will detect the light's internal temperature in real time and adjust the output based on this.
The MH20GT is also rechargeable with a USB cord that is included. Plug one end into the flashlight and the other into a usb slot in a computer, or wall adapter. The side button will flash while the light is charging and hold steady when the charging is complete. If the light rapidly blinks, there is an issue such as the battery being incorrectly inserted.
Beam pattern
The Beam pattern on the MH20GT is similar to the P12GT, other than the hot spot being slightly smaller. The spill is medium brightness but very clean and free of rings.
The New CREE XP-L HI V3 Emitter on the MH20GT is domeless, meaning that there is no dome over the diode, it is just flat.
It is also noticeably smaller than the P12's and MH20's XP-L2 U2 LED
The MH20GT also features a smooth reflector which produces a surprisingly nice smooth beam pattern with the hotspot nicely transitioning into the spill.
*IMPORTANT* In the shots below, the weird shape of the spot is because I had the light angled upwards so that the flashlight body didn't cover any of the spot. The actual spot shape is very round
ISO 100, f/3.5, 1/60
ISO 100, f/3.5, 1/250
ISO 100, f/3.5, 1/2000
Personal Opinions
The MH20GT has incredible range for it's class and size. I never thought a light under 4 inches could go as incredibly far as this does. The light is perfect size to carry in any pockets I have put it in. The brightness is also very impressive and blindingly bright even at several hundred meters if looked at directly when it's pointed at you. I feel that the crenelated bezel is good for protecting the glass and front end of the light.
The user interface is great! I love that the 5 main modes are well spaced. I also really like that the strobe "special" modes are "hidden" and require holding of the side button in order to activate. The memory feature is always great as well so that you always know which mode will be on when the light is activated.
The Blue LED in the side button is bright and easy to see on my light.
I absolutely love the overall feel of the MH20GT. I think this is my favorite Nitecore light now along with the P12GT. The throw is absolutely incredible, especially for a light of this size. The grip is very comfortable and I love the 2 stage switch. When I first heard of the MH20 I was hesitant as to whether or not the button and modes would be confusing when crammed into one button but Nitecore did a great job with the User Interface making it easy to understand and to use. I do love the beacon as well. if you activate the beacon on the light and set it down at night, it will be easy to find.
Another great feature of this light is that it has a very low mode of 1 lumen. Many manufacturers overlook this feature that I find very valuable. If you are out walking your dog or walking in the woods or on a trail and don't want to kill your night vision, this is great to have because it is just enough to see your surroundings but it won't hurt your night adjusted eyes. Next is the extreme brightness. This light will reach out several hundred meters. *Pictures coming soon* My backyard is 146 meters from the house to the forest start. This light reaches out there with enough brightness to clearly see everything at that distance. A deer's eye reflection would be able to be seen very far beyond that as well. The beam pattern is great because it has a good balance of flood and a good hot spot in the center. The hot spot is a little small to use in close range, but at a distance it is great because you have a semi-large area that is very well illuminated.
I can for sure see this being a very, very valuable EDC light for anyone because the size, durability, brightness, and throw. The only downside I can find to this light is that there is no tactical switch. However; this is not really a downside because the MH20GT isn't made to be a tactical light. This is perfect for anyone who wants an EDC light that is small and can be used for almost anything!
I honestly can't find anything bad about this light! I am extremely impressed with every feature of it and the ingenuity that has gone into building the MH20GT and I now carry this light almost every day.
PROS
Brightness
Throw
Flood
Battery readout
Grip
Low voltage warning
Good runtime on all modes with incredible runtime on low
Waterproof
shock resistant
CONS
SOMETIMES the light does not come on when I push the button. This is fixed by simply pressing it again. Maybe I don't push it all the way sometimes?
Manufacturer specs
Max Lumen: 1000
Beam Distance: 362m
MSRP: ~$99
In the box
Appearance
Physical Tests
Beam pattern
Personal Opinions
PROS
Brightness
Throw
Flood
Battery readout
Grip
Low voltage warning
Waterproof
shock resistant
CONS
