Pinter
I wondered what is my _real_ battery capacity in a direct drive configuration. So I made some runtime measures on my Lambda Megalite.
LED: Luxeon 5W U4T binned on Lambda heatsink
LED's forward voltage @700mA is 6.40V in operation (when warmed up), 6.5V @ 700mA just 5 seconds after powered on.
This config is a resistored (0.1 ohms) direct drive in a Mag2D using 6 AA cells
Rechargable: 6xSanyo NiHM 2100 (AA)
I put a 0.1 ohm resistor to measure the current.
The measurements were made on a minute resolution. The table below is contains less data.
Continous runtime was 1h37min till current dropped to 700 mA.
[min] Vf(led)[V] I[A] P(led)[W] Cumulated used capacity[mAh]
0 6,93 1,360 9,42
5 6,77 1,200 8,12 126
10 6,72 1,149 7,72 223
20 6,68 1,151 7,69 414
30 6,66 1,162 7,74 607
40 6,65 1,148 7,63 800
50 6,63 1,123 7,45 988
60 6,60 1,084 7,15 1172
70 6,57 1,036 6,81 1349
80 6,54 0,941 6,15 1517
85 6,50 0,878 5,71 1592
90 6,46 0,811 5,24 1662
95 6,42 0,732 4,70 1726
<font color="red"> 97 6,40 0,697 4,46 1749 *** 700 mA limit reached </font>
100 6,36 0,624 3,97 1782
105 6,30 0,545 3,43 1831
110 6,37 0,563 3,59 1881
112 6,31 0,493 3,11 1898
As you can see, usable capacity is much less than advertised. (It is of course not Sanyo's fault, this is true for only this application)
The 2100 mAh theoretical capacity in this case is only 1750 mAh. Sad but true: 83% only.
Not that the "usability" limit was of my choice: till the current dropped to 700 mA.
(If we watch till 500 mA, capacity was 1900 mAh.)
This efficiency of 83% when direct drived is comparable with those current regulators that are able to gain the last energy from the batteries. Of course there may be other factors also.
0 6,93 1,360 9,42
