Pics of IT
here are some pics of it, I don't know how well they will help but here they are.
Hello all just got back from vages, and well nothing has changed there.
I looked at the circuit on the link, and it looks the same to me! Even uses the same transistor! But I have found a very cheep repacement
and the winner is (PN2222A) and even works better in my circuit,
Now the bead is a much different matter! I've been in contact with Amiadon (Ferrite maker), and they are sending me out about 3 different sizes, I had the size in .mm but that don't help us americans much, I could hear the guy helping me on the phone scraching his head! hehe you can see the bead in the pics I took and how bright the lite is after 113 hours on the same AA battery.
The battery is nothing special just a energizer E91 AA that I had here at the house.
KenBar if there is anything I can do to help you let me know, I'm sorry you got a bunch of stuff that don't work, but I did say you can't get this stuff at RadioShack, they just don't have anything that will work that I know of, I can give all the web site info again of you need it, or more and better pics of it?
To test the circuits I use a bread board first and connect up everthing and then make it up!
Ok Forrest I'll try and answer all your questions
As far as I know you can use any kind of power source I haven't tested it above 1.5V yet but think you can use up to 3V or two AA batterys.
Light intensity; well I don't have a light metter I was using my eyes to get the totals I should have said that.
As far as how many LED's this could be used to power? I think only one! but more testing will give the answer on that one.
the schematic is at that web address in UK already given but the info about the bead and how many turns of what kind of wire is left out
I'm working on that now I know the size of the bead in metric but don't know how to convert it. I'm getting 3 different sized sent to me asap, and should be here next week.
What frequency does the power converter switch at? hehehe I don't know sorry, but if I did i could have made a better one I think.
I must say that when I got home I though that it would be dead, but it's still going
and it's not very bright but IT'S STILL GOING!
does anyone know how long a task lite will run if left on?
