Sold/Expired all sold/withdrawn:Custom Lights Blowout. a couple I made, plus others. (drops 3/1)
mcbrat
Iowa
Custom Lights Blowout. Need to start paying for my new equipment ! :)
No batteries included unless otherwise noted.
Cross posted on a couple of sites.
stay tuned as I'll be adding more.....
******* SOLD/WITHDRAWN ITEMS BELOW ********
1. Brat Guy Damascus 18350 triple. $WITHDRAWN .
This was just the second light I made, (all my lights at this point are still what I consider prototypes as I continue to learn),
and was all done on my old mini-lathe. First light was aluminum, and I thought I'd just jump right into something a bit different.
Material is 4340 + 1050 steel damascus (carbon) and already had a hole bored in it that I then had to enlarge for 18350.
in the tail end, due to the pre-existing bore, I threaded deeper, and used one of my boot rings as the switch shelf, then
the McClicky install. the exposed boot ring is a better fitting ring made of Nickel Silver now.
As stated, this was my second light and first attempt at 28 tpi threading as I wanted to use a Mac/Okluma/Trident style pill.
I had some problem with the threading, (came to find out later that I had one of the change gears wrong, so it was actually
threading at 14 tpi) but with this material and the limitations of the mini-lathe, plus the fact I was still learning, it ended
up looking really weird, but actually fits together good and solid. A copper pill was able to thread in okay since it was softer
than the aluminum, and kind of molded itself to the larger pitch threads since it was double.... engine is fully removeable if need be.
Due to the short length of the head, I had to shorten the bare okluma pill with a grinder (lathe was broken at that time), and during the the grinding process
the copper got hot enough that the teeth of the vice grip sunk into the soft copper!
so it's not pretty either, but functional.
I used a Qlite 3.04A driver with L-M-H as I like simplicity in my drivers.
The triple emitters are beautiful Nichia 219B and this was probably my favorite tint of all my lights.
There is a green glow gasket, and now has a black switchboot. the boot can be swapped out, as well as the
glow gasket for whatever I may have on hand when this sells.
Clip is one of my Alien Ti Clips that has been heat colored.
there are o-rings in all the expected places, but water protection has not been tested :)
Plus with this being Carbon Damascus, it will have a tendency to rust if it gets wet.
I use RemOil on it, and it seems to do a good job of keeping any corrosion at bay.
5. Mac's Customs 18650 with Gunmetal/Tungsten Cerakote SOLD - $125 .
This has one of 2 proto-type heads Mac made for this series. This one has been uses, and shows cerakote wear.
This came to me with a dead driver, so I replaced the original 2.8A driver with a 3.04A driver, but kept the great warm tint XM-L emitter with the reflector.
I have since made a custom copper pill and installed a 6 level FET driver and a Quad Nichia 219C board, along with an optic and glow pad.
This is a blaster on high!
Comes with both engines.
http://www.indysworld.com/sale/Mac-18650-XML-1.jpg
http://www.indysworld.com/sale/Mac-18650-XML-2.jpg
http://www.indysworld.com/sale/Mac-18650-XML-3.jpg
http://www.indysworld.com/sale/Mac-18650-XML-4.jpg
http://www.indysworld.com/sale/Mac-18650-XML-5.jpg
http://www.indysworld.com/sale/Mac-18650-XML-6.jpg
http://www.indysworld.com/sale/Mac-18650-XML-7.jpg
http://www.indysworld.com/sale/Mac-18650-XML-8.jpg
http://www.indysworld.com/sale/Mac-18650-XML-9.jpg
E series Copper lego SOLD - $225 .
RPM Copper Tail.
McGizmo Aleph CR123 body
Brat Guy Copper Mule Head
DatiLED 1.4A (16340 only) Copper engine with Nichia 219B emitter
http://www.indysworld.com/flashlights/e-lego-cu-1.jpg
http://www.indysworld.com/flashlights/e-lego-cu-2.jpg
3. TnC Damascus/Oak P60 host. $450 - SOLD .
Custom made from the same batch of Damascus as the Mr. Bulk Dam Cham
Oak section has a brass core. Originally made as a 18350, and I had Chris make the extension so I could run 18650 or 2x18350.
Prometheus Ti Clip.
No drop-in included.
http://www.indysworld.com/sale/dam-oak-1.jpg
http://www.indysworld.com/sale/dam-oak-2.jpg
http://www.indysworld.com/sale/dam-oak-3.jpg
http://www.indysworld.com/sale/dam-oak-4.jpg
http://www.indysworld.com/sale/dam-oak-5.jpg
8. E2 Lego; TnC/Surefire/Oveready V5 371D board $200 -SOLD .
The TnC head was customized along with a modified pill to run a Lux-RC 371D board.
RD33 XP-L HI (red secondary). takes one 17670 battery, or 2x16340 IMR.
Surefire E2L body looks like new.
Ti Bezel ring (I believe) not aluminum. I guess it could be SS....
http://www.indysworld.com/sale/e2l-TnC-371d.jpg
9. Lummi package deal $250 - SPF .
Raw Ti (green trits)
Mee Ti Clip (green trit)
Raw NS
4 batteries
USB Charger.
http://www.indysworld.com/sale/Lummi-deal.jpg
2. Brat Guy Smoothie Prototype in Nickel Silver $200 - SOLD .
This is light number 6 that I made.
Nickel Silver (Weiland N-31). These were bar ends from a company using it to make musical instruments.
Ti Boot retaining ring.
Brat Guy Ti Alien Clip.
Qlite 3.04A driver
Triple XP-L HI V2 3A 4750-5000k on Custom Copper Pill
2mm mineral glass lens
http://www.indysworld.com/sale/bge-smoothie-1.jpg
http://www.indysworld.com/sale/bge-smoothie-2.jpg
http://www.indysworld.com/sale/bge-smoothie-3.jpg
http://www.indysworld.com/sale/bge-smoothie-4.jpg
4. HDS Ra Ti Clicky SOLD - $750 .
This is a catch and release for me. Wonderful original emitter. I haven't carried as I don't want to ding it up.
http://www.indysworld.com/sale/HDS-Ra-Clicky-Ti-1.jpg
http://www.indysworld.com/sale/HDS-Ra-Clicky-Ti-2.jpg
http://www.indysworld.com/sale/HDS-Ra-Clicky-Ti-3.jpg
http://www.indysworld.com/sale/HDS-Ra-Clicky-Ti-4.jpg
6. Mac's Customs EDC SST-50 Aluminum SOLD - $300 .
This one has had a little work done to it. body and head have been cleaned up to remove dings and work with the fitment of the extender.
This light is an early one that was made for a 16340 battery.
I made the extender so it can be run with a 17670 battery.
The original SST-50 engine has been upgraded by Charles Wiggins with a 17DDM driver with guppydrv.
Also included is a Brat Guy triple conversion engine with a qlite 3.04A driver and 3x Nichia 219C emitters.
http://www.indysworld.com/sale/mac-extender-1.jpg
http://www.indysworld.com/sale/mac-extender-2.jpg
http://www.indysworld.com/sale/mac-extender-3.jpg
http://www.indysworld.com/sale/mac-extender-4.jpg
http://www.indysworld.com/sale/mac-extender-5.jpg
http://www.indysworld.com/sale/mac-extender-6.jpg
7. Peak Brass Matterhorn/Eiger SOLD - $20 .
This is an old 3 LED Peak Matterhorn head, with one dead LED. Body is a newer one, but is Non-QTC.
http://www.indysworld.com/sale/peak-matterhorn-eiger.jpg
http://www.indysworld.com/sale/peak-matterhorn-eiger-2.jpg
Crazyeddiethefirst
Southern California
Re: Custom Lights Blowout. a couple I made, plus others.....
Hey Mick,
PayPal sent-Nice to do business with you again! I did not see any postage cost mentioned-if I owe you more, let me know & I will send promptly!
mcbrat
Iowa
got it! will go out tomorrow morning. thanks!
Greenbean
WNC
Wow, out of my price range but beautiful work there bud!
Crazyeddiethefirst
Southern California
Received the light quickly, exactly as described, Thanks Mick, always a pleasure to buy from you(or trade)....
maxspeeds
Oahu, Hawaii
I'll take #9 if they are both lights are titanium. PM incoming
edit: I'll still take the package with the Ti Raw and NS Raw.
Paypal sent
mcbrat
Iowa
Thanks. Brat Guy Smoothie proto sold as well.
mcbrat
Iowa
TnC Damascus and 371D Lego sold. all that remains in the Brat Guy Damascus, and the Modified Mac.
