I recently purchased a Foursevens MMR-X from someone, after I saw that Foursevens has gone out of business. I searched around and found one that was supposed to be new and unused. When I received it, I found that it does not have the plastic disc in the tailcap, which is used to block the outer spring contact for the battery in the head end of the flashlight.
My understanding is that this is necessary if one wants to use a regular 18650 battery in this flashlight, otherwise it will short by have both a negative and positive contact touch the positive end of the battery. (The MMR-X comes with a special version of the 18650 designed to use both of these contacts, so that the battery can charge in the flashlight. This is explained in this review: http://www.candlepowerforums.com/vb...L2-1x18650)-Rechargeable-review-RUNTIMES-BEAM.)
The person I got the flashlight from said that the disc in unnecessary and stopped shipping with the MMR-X after a couple years. Is this correct? Can I use a regular 18650 battery in the MMR-X without masking the extra outer spring contact in the head end of the flashlight?
Thanks for any feedback on this.
