MedusaOblongata
Not new to flashlights, but new to rechargeables.
I know, use the search function. I did. 2 hours later, I'm more confused than before. I have a Nitecore Intellicharger i4 (V2). The flashlight I use most is a Lumintop Prince, but I also have a Olight s20, Fenix PD31, SF G2 with Klarus (I think?) LED drop in, and SF G2X LE (I think, 2 mode OEM LED) on my rifle.
Runtime and low self discharge (and a flashlight that doesn't explode in my back pocket too often) are more important to me than peak turbo brightness (modern LED flashlights are plenty bright for my needs).
I know I want protected cells, and they have to be button top. I know I'll end up leaving the cells on the charger overnight, and running them in the flashlight until they die before recharging, at least sometimes. I see batteries from 2000-3600 mAh, from $5-$35. I know that known brands are better (safer and better performance) than cheap Chinese knock offs, but I also know that a lot of the smaller brands are just rebranded name brand cells, but I don't know which ones.
I'm looking at http://goinggear.com/flashlights/batteries/olight-protected-3400-mah-lg-18650-3-6-volt-battery.html and https://www.batteryjunction.com/186...h_return=all&Catalogbattamperehour=2993||3600 , but I know I'm not qualified to make the best decision.
I'm not a heavy user, and a set of primary 123s often lasts me a couple of months.
What's the best choice under $20 ea?
Thanks in advance,
Medusa Oblongata
Thanks in advance,
Medusa Oblongata
